Wiring Run Around The Diff
Guest PaulTVR
Guest PaulTVR
I've installed the fuel pipes, next job is the wiring run. I used cable tie holding clips down the tunnel for the fuel and wiring. When I get to the diff area the simplest way to route the wiring seems to be to cable tie it to the brake line, is this a no-no for the iva? DSC_0891_zps6kquwx8n.jpg
As all the above, but also consider using split convoluted hose to route the wiring in.
Gives protection to cable abrasion (you have to consider & prevent this for IVA).
Easier to get clips to suit the size.
Looks better (IMO) than a bare loom
Guest PaulTVR
Sorry not the clearest photo, the loom is in convoluted split tube, I tied it to the brake pipe, but is plenty clear of the inner cv joint. I will put some clips on the chassis though. I have run the fuel down the N/S and the Brakes and electrics on the O/S
Edited by PaulTVR
