RHOCaR End of Season Bash
Come and join us for our Annual event  on 14th to 16th September
Camping, Family Fun,  Evening Entertainment and like-minded Company
Full Details and entry form here:
http://www.rhocar.org/index.php?showtopic=46637
Engine Mounts
  • Please log in to reply
12 replies to this topic
#1 DAVE1954
DAVE1954
    Wheely good builder!
  • Community user
  • 131 posts
  • Car type:robin hood 2b
Posted 12 October 2017 - 03:48 PM
Hi a friend of mine has bought a part built RH , no engine or gearbox, he wants to put a zetec, how do you work out position of fixing engine mounts cheers. Dave
#2 jaimo
jaimo
  • RHOCaR 18
  • 1,682 posts
  • Car type:robin hood exmo
Posted 12 October 2017 - 04:27 PM
Get sierra cvh ones they fit if sierra based
Will it ever be a good runner ?
#3 DAVE1954
DAVE1954
  • Community user
  • 131 posts
Posted 12 October 2017 - 04:34 PM
Hi he hasn't any mounts at all on it, as I said with no engine or box how do you workout were to weld mounts cheers
#4 lotusPaul
lotusPaul
    Champagne, mouthwash of champions
  • Community user
  • 895 posts
  • Car type:S7 steel mono
Posted 12 October 2017 - 06:22 PM
Can you tell us what model RH?.what length is prop, what box is being used? Silver or blacktop zetec?
Give us a clue, some pics perhaps
#5 theduck
theduck
    Chairman
  • Admin
  • 3,578 posts
  • Car type:Sierra S7
Posted 12 October 2017 - 07:41 PM
As Paul says some more detail would help, but sounds like he will need to mock it up in place.
#6 DAVE1954
DAVE1954
  • Community user
  • 131 posts
Posted 12 October 2017 - 07:52 PM
Hi Sierra diff, no prop at moment, he's got a type9 gearbox, intends to buy blacktop, is it a case of putting all on the floor fixed together and getting tape measure out.
#7 theduck
theduck
    Chairman
  • Admin
  • 3,578 posts
Posted 12 October 2017 - 08:07 PM
More a case of using a crane and lumps of wood to position it roughly in the car, then make the engine and gearbox mounts and then measure for a prop. Or if he manages to get a prop around the right length then position engine and box to suit but again, really need to mock it up in the car.
#8 lotusPaul
lotusPaul
  • Community user
  • 895 posts
Posted 12 October 2017 - 08:24 PM
Just like what Duck says. Is this for S7?
#9 DAVE1954
DAVE1954
  • Community user
  • 131 posts
Posted 12 October 2017 - 08:31 PM
Hi don't know if it's s7, it's a stainless chassis,or stainless look like.
#10 Bob Tucker
Bob Tucker
    It'll be OK in the end, if it's not OK, it's not the
  • RHOCaR 18
  • 4,922 posts
  • Car type:2B + 16vXE +wishbone conversion (&MX5)
Posted 12 October 2017 - 09:50 PM
http://nw.rhocar.org...ntification.htm
It always takes longer to put it right than do it right.
#11 Peter Bell
Peter Bell
    Bus Pass Boyz
  • RHOCaR 18
  • 2,671 posts
  • Car type:Mk1 Sierra 7
Posted 12 October 2017 - 10:22 PM
It could be a monococque which has folded boxes for the mounts, see the following link.
http://www.rhocar.or...+engine +mounts
You don't stop playing because you get older, you get older because you stop playing!
#12 agent_zed
agent_zed
  • Community user
  • 2,893 posts
  • Car type:2B with double wishbones
Posted 13 October 2017 - 07:52 PM
apart from the gearbox having to fit in the gap you also have to make sure the gearstick comes out in the correct place as you don't want to end up with it hitting the dash board etc.
I can't quite remember but someone on here will know but i think the MT75 gearbox has a remote shifter in which case it could be modded to adjust the position if necessary. The mt75 is also a stronger box and you can probably sell the type 9 for more than the cost of a mt75. Although they are bigger so check space to fit.
I also have a feeling a commonly used engine mount is the landrover mounts which seem cheap enough....
http://www.ebay.co.u...738.m2548.l4275
can't see why they wouldnt work.
As above though just a case of mocking it all up. measure measure and measure again.
Alternatively if you are making a new prop anyway you could look at getting an mx5 engine and gearbox as they should fit and possibly less hassle/cheaper than joining the blacktop to type nine.
#13 Bob Tucker
Bob Tucker
  • RHOCaR 18
  • 4,922 posts
Posted 13 October 2017 - 10:31 PM
+1 for the Land Rover mounts.
