Any Engineers In The House?
  • Please log in to reply
15 replies to this topic
#1 Thrashed
Thrashed
    Wheely good builder!
  • RHOCaR 18
  • 789 posts
  • Car type:zero
Posted 27 March 2016 - 08:13 PM
Hi guys
i am making a jacking beam for a ramp i have made and need to work out how much weight box section will take.
The bar will be 2m long and jacked at the centre point.  The max size box section i can use is 40x40.  Thickness can be anything up to 4mm.
I need it to be able to take at least 2 tonne so that i have a 100% safety margin.
Can anyone help with calculations.
Steve
#2 peter2b2002
peter2b2002
  • Community user
  • 3,916 posts
  • Car type:2B 2ltr efi wishbone on the road april2004
Posted 27 March 2016 - 08:20 PM
Google it's been over 30 years since I did these calculations
peter2b
#3 Thrashed
Thrashed
  • RHOCaR 18
  • 789 posts
  • Car type:zero
Posted 27 March 2016 - 08:24 PM
peter2b
Thanks, tried that, but made not sense and dont wont to risk my life of google.
#4 2b cruising
2b cruising
  • Community user
  • 4,225 posts
  • Car type:2b 2ltr dohc 8 valve wishbones.
Posted 27 March 2016 - 08:35 PM
If it is welded both ends to a jacking plate, its strength is much greater.
Use the max gauge possible. Put a length at an angle on the kirb and ask a friendly bus driver to run over it. 😬
You should be able to jack it up somehow to find its strength. Nothing like a bit of practical instead of math.
Edited by 2b cruising, 27 March 2016 - 08:42 PM.
The beatings will continue until morale improves.
#5 Shaft
Shaft
    AKA... Gavin
  • Moderator
  • 3,199 posts
  • Car type:Shogun RHOCaR Support Vehicle
Posted 27 March 2016 - 08:40 PM
have a read here. It's complex to explain without an essay.
Be aware as you're using it for jacking as the 'bounce' effect creates a dynamic load rahter than a 'static' load.
Also, the 8:1 ratio for SWL if wanting insurance. i.e lifting 100kg swl the beam must test at 800kg.
http://www.engineers...calc_menu.shtml
  • CMA likes this
Posted Image
RHOCaR Show Support Vehicle and my Tin Top Accommodation.
#6 Thrashed
Thrashed
  • RHOCaR 18
  • 789 posts
  • Car type:zero
Posted 27 March 2016 - 08:54 PM
Thanks, saw these calcs and this made no sense.  Never considered the bounce effect.   Got no issue with a 8:1 ratio for safety.
Is anyone able use these calcs to telling me the load bearing of a 2000x40x40x4mm mild steel box section.
#7 Shaft
Shaft
    AKA... Gavin
  • Moderator
  • 3,199 posts
Posted 27 March 2016 - 10:09 PM
It's unfortunately not as simple as A+B=C Steve.
There are numerous variables to take into account to glean your answer.
You say 2m long but the point of load won't be a singular point in the middle so you'll need to know how your proposed 2 tonne load will be spread over the length.
To learn the swl you need to firstly work out the deflection for a given load at a given point, but how far along the 2m? (Hence the need to know load spread?)
Sorry to be vague but that's why I posted the link above; more for explaining what I'm getting at rather than using it as a calculator.
Posted Image
#8 Thrashed
Thrashed
  • RHOCaR 18
  • 789 posts
  • Car type:zero
Posted 27 March 2016 - 10:15 PM
Thanks Shaft
Been doing some calcs and the deflection of a 2m bar is 0.01045 inches and the bending stress is 120.47 psi.
Going to work through the website you gave me.
Thanks for the help.
#9 Shaft
Shaft
    AKA... Gavin
  • Moderator
  • 3,199 posts
Posted 27 March 2016 - 10:20 PM
No worries. Welcome to my world! Lol.
Have a read here also, it talks through the fundamentals of deflection and the ratio of compression to tension versus the neutral line of any given beam but more in Layman's terms than the 1st link.
I'm happy to help with any calcs if you need me but you'll learn more from good old fashioned reading.
https://en.m.wikiped...rg/wiki/Bending
Edited by Shaft, 27 March 2016 - 10:22 PM.
Posted Image
#10 richyb66
richyb66
    Club Secretary
  • Committee
  • 2,255 posts
  • Car type:2B wishbone 4.6 V8
Posted 28 March 2016 - 08:49 AM
Steve, I'm off work next week but if you give me a sketch on Wednesday night I'll get one of our CAE guys at work to run it through their FEA software.
<p>Warks, Worcs, W Mids area meet. Last Wednesday of the month 7PM onwards, January to November. Malt Shovel Toby Carvery, Coventry Road, Nr Stonebridge, Coventry, CV7 7HL <a data-ipb='nomediaparse' href='https://www.google.c...E'>here</a></p>
<p>
#11 Thrashed
Thrashed
  • RHOCaR 18
  • 789 posts
  • Car type:zero
Posted 28 March 2016 - 09:10 AM
Thanks Rich. Will bring with me. See ya Wednesday
#12 Ian & Carole
Ian & Carole
    Super builder
  • Community user
  • PipPipPipPipPip
  • 5,036 posts
  • Car type:6 speed
Posted 28 March 2016 - 10:26 AM
It's threads like this one that  confirm what a great club this is.
We must all save our £15.00 / year membership every time we ask a question on  here.   :clapping:  :clapping:  :clapping:  :drinks:
#13 Tim Norman
Tim Norman
    Mr President
  • Moderator
  • 2,586 posts
  • Car type:Scimitar GTE
Posted 30 March 2016 - 09:23 PM
I have a 2T jacking beam from sgs engineering I can stick a tape  on it tomorrow if that helps?
Tim Norman
RHOCaR
"President"
Life is not measured by the number of breaths you take, but by the moments that take your breath away!
#14 Thrashed
Thrashed
  • RHOCaR 18
  • 789 posts
  • Car type:zero
Posted 30 March 2016 - 11:01 PM
Thanks, that would be very helpful. If you can measure the width and height of the box section they use plus what gauge metal the box section is made from that would be great.
#15 Tim Norman
Tim Norman
    Mr President
  • Moderator
  • 2,586 posts
Posted 31 March 2016 - 03:56 PM
Jacking beam
Centre section is 95 x 50mm 4mm thick
Tim Norman
RHOCaR
"President"
