V6 Cologne Pistons
biksz
You do realise the V6 piston deck height is lower than Pinto Pistons so on Pinto rods they will be 1.5mm down the bore at TDC meaning you have to deck the block quite a bit.
Cosworth rods are 1.5mm longer but have floating gudgon pins so Pistons need machining for circlips
Yeah I do realise that snapper Paul ut looking into what I can get away with as I have a 2.1 block already so it might have been decked already
Edited by biksz
