Ebay Advert
Guest Howleybar
Guest Howleybar
https://m.ebay.co.uk/itm/MK-Indy-R-Duratec-engine-like-Caterham-Westfield-etc/173222224240?hash=item2854d96170:g:NkEAAOSwxwRarZHj
Like the sound of this, how easy would it be to add a windscreen and remove the cage. Also sound like the diff needs work, what sort of cost could this incur. The big draw for me is its literally on my doorstep
Many thanks
Chris
You also need to get the replacement engine registered.....its currently
showing as a 1.6
https://vehicleenquiry.service.gov.uk/ViewVehicle
probably best to speak to mk sportscars to check that the front downtubes are not structural,
& the cost of a windscreen, a frame and the side supports.
replacing a diff should be easy if you can find one the same as the one fitted.
An LSD diff will need new driveshafts, and I believe a disk brake conversion
