Telemetrix Tacho Not Working With Edis
baj25
I connected my tacho to edis4 today, but it did not work. It works fine with the motorcraft amp and single coil, with tacho signal taken from coil -ve. On the edis, i connected the 2 coil negatives through diodes ( no zener) to the tacho but zilch. Anyone else had this trouble and if so how did you get around it? Ta, brian
wot you lost me if you are running an eddis and you connect a tacho to it there is only one connection I have tried running a tacho from megajolt but would not work so now I run it straight from edis
Edited by tractor
I am confident the diodes are the right way round. It seemed so easy, use the coil input as before! I had a look behind the dash and i am connected to the red/blue wire so it should work. I looked for the white/black wire for ecu tacho input but i could not see it, need to do some yoga and then get head back in footwell!
