Headlight Madness
Guest 2Bbuilt
Guest 2Bbuilt
Gents
really need your help with headlights on sierra 1988 loom.
i have wiper and indicator stalks of 87gb variety.
issue is
1. get side lights, then dipped beam (using right stalk)
no flash or main beam on left stalk
2. Put earth to steering column body (top bit between switches)
get side lights but no dipped beam
get flash and main beam but only on right hand light
in both cases i have small spade earth to spade connection on top of wiper (right) stalk
relays all changed, checked a double checked for dodgy earths.
can you help!!! before we go mad, 2nd week on it now
Guest peter2b2002
What loom are you using? If its the donner one it could be a relay not working I had it on mine I cut too many earth wires out of the loom 1 being the earth from the main been relay
Peterb
Guest 2Bbuilt
peter
it is the sierra loom, earths to relays? I will check
what I did not mention was right hand light has a blue/white wire, which according to the wiring diagram acts as switch earth I think. this is connected to the earth position on the bulb. therefore no "normal" earth to this bulb, although there is to the sidelight.
Guest 2Bbuilt
ok done some fidling
got
side lights
dipped beam
flash on main beam
no main beam when stalk moved forward
continuity across stalk pins 56
when flash is operated it looks like it takes same route as main beam, now i am confused..............why does it not work
Guest 2Bbuilt
I will give that a try this weekend
need to move on, spending too much time on this job at the cost of others.
will give it this weekend, after that i will come back to it later, may have one of those flashes of inspiration whilst walking round Asda (other superstores are available).
still looking to how i can cut out the dim/dip lighting though, i hear you can put wire in to short it out, i have 2 relays though
Guest 2Bbuilt
Its done, at last
turned out to be the 2 little wire that go to the dipped beam relay and the inherited fuse box also had the wrong relay in!!!!
all sorted now, thanks Peter for the help
result of all this is that i now know my entire wiring loom Intimately .............
