Pinto Problem
jaimo
Well stu and i took head off today and discovered this
The problem has been number 3 fouling plug and burning oil point of misfire
Suspecting cvh valve stem oil seals but got to check guides
And orther ideas
You certainly need to look at valve guides , have them bored out and bronze ones fitted with proper seals [ all of them !!] mick . do it properly and you only do it once :acute:
When i took no 3 valve stem seals off there was oil all below alot lot more than rest so dont u think cud just be valve stem seals the guides were apparantly checked when skimmed is there any why to check them
No bob u are correct i was abit taken back by that dont quite understand that unless the oil on plug is causing the fuel not to ignite fully so keeping piston clean prop not but what else would explain it
Just replace them! they are not expensive if you have any apreciable play in the guides it will FUBAR the seals! .I might have some left will look them out , a clean piston like no3 COULD be h/gasket weep , are valve stems showing any wear ? really a full head recon is signalled as before do it right and you only do :acute: it once mick
Had head pressure tested valve reground skimmed new cam bearing etc only guides not done as they said they fine and dont need doing so really apart from guides is a recon head
No sign of head gasket failure
Could be unburnt fuel in there as smells
of petrol and oil in engine and exhaust
Might ring headmaster ask how much for guides might even get new valves but no wear on them eiter
