RHOCaR End of Season Bash
Come and join us for our Annual event  on 14th to 16th September
Camping, Family Fun,  Evening Entertainment and like-minded Company
Full Details and entry form here:
http://www.rhocar.org/index.php?showtopic=46637
600Cc Bike Carbs Onto A Pinto 2L
  • Please log in to reply
9 replies to this topic
#1 F1 2ERO
F1 2ERO
    Newbie Builder
  • Community user
  • 3 posts
  • Car type:Zero
Posted 22 June 2017 - 11:29 AM
I've had this problem for quite a long time. I got the carbs from RH Richard and was told they were ready to go. The problems I have are the engine backfires when the throttle is dead (not accelerating or slowing) there is a very strong smell of fuel ( it is dissolving the air filter) I have been told that I need to get new jets or it's a fuel pressure regulator. I'm not sure which way to go has anyone had similar problems or do you have any ideas?
#2 theduck
theduck
    Chairman
  • Admin
  • 3,562 posts
  • Car type:Sierra S7
Posted 22 June 2017 - 11:48 AM
Bike carbs run at very low pressure and so you are best running the fuel pump from the same bike as the carbs came from. No two cars are ever the same and so the setup on the carbs may be good enough to get it going you still need to get them properly setup for your car.
#3 DanE
DanE
    Electrickery master
  • RHOCaR 18
  • PipPipPipPipPip
  • 6,594 posts
  • Car type:SSC Stylus Supercharged
Posted 22 June 2017 - 01:26 PM
You need to go to a dyno and get them setup properly.
Ssc stylus with a supercharged zetec 242bhp and 253ft lb of wheel spin.
#4 Thrashed
Thrashed
    Wheely good builder!
  • RHOCaR 18
  • 760 posts
  • Car type:zero
Posted 22 June 2017 - 01:48 PM
Hi.
I have ZX6r bike carbs on my pinto. I have a facet fuel pump and a pressure regulator set to 1.5 psi. Most bike carbs can suffer a max of about 3psi.
I have a Sytec regulator which cost less than £30 and a Facet red top fuel pump, which will run at about 7psi. I needed the red top to get the fuel flow levels as the original Facet posi flow has almost the right pressure (max 4 psi) but didn't deliver enough flow as I found out on the first rolling road session!
I then had it set up on a rolling road, which involved drilling out standard jets.
#5 Dave Ed
Dave Ed
  • RHOCaR 18
  • 278 posts
  • Car type:Exmo days from an mot. its been like that for 5 years !
Posted 22 June 2017 - 03:02 PM
Would the standard pinto fuel pump and a regulator be sufficient for a bike carb setup Or is a Facet pump and regulator the best way forward?
time is relative, it's the distance that screws me up !
#6 maccavvy
maccavvy
  • Community user
  • 2,009 posts
  • Car type:Holden monaro and a Ford f150 lariat v8
Posted 22 June 2017 - 08:50 PM
i ran a standard mechanical pinto pump with a sytek regulator set to 2psi but has them jetted and set up on the rollers...
2b sold .... awaiting new arrival
#7 Dave Ed
Dave Ed
  • RHOCaR 18
  • 278 posts
Posted 22 June 2017 - 08:58 PM
Ok that's good, thanks.
#8 F1 2ERO
F1 2ERO
    Newbie Builder
  • Community user
  • 3 posts
  • Car type:Zero
Posted 23 June 2017 - 07:32 AM
Hi thanks for the help does anyone know a good place in north Kent Gillingham to have the Zero set up on a Dyno / Rolling road and also where I can get the suspension set up.
#9 Al Milton
Al Milton
  • RHOCaR 18
  • 1,740 posts
  • Car type:Super Spec
Posted 23 June 2017 - 08:30 PM
Google BD Engineering at Newington (they are on an industrial estate just off the A2), not a million miles from you.
I found them great for setting my emissions, another member had a nightmare with them
#10 Bob Tucker
Bob Tucker
    It'll be OK in the end, if it's not OK, it's not the
  • RHOCaR 18
  • 4,898 posts
  • Car type:2B + 16vXE +wishbone conversion (&MX5)
Posted 24 June 2017 - 01:19 PM
Sanspeed in Bexleyheath have always been helpful for me, but that's with DHLAs...best to check if they can help with bike carbs
It always takes longer to put it right than do it right.
