Pinto Ignition & Dwell
Thrashed
A distributor with points and even a distributor with a black box does not give you the flexibility of a programmable ecu.
I can set cranking advance on my high compression engine to get it started with ease, then set idle advance and then precisely when the advance starts after idle upto peak advance with whatever cam I decide to use
Try that with a weight and spring advance of a distributor.
As for power a distributor will only allow you to set it up for one rev range and the curve is fixed, you will miss out on torque where as a programmable ignition can be mapped to get the best out of the whole rev range
  • Like 2
