Speedo Cable Wont Fit
itllbedonesoon
Hello All,
I have a MT75 gearbox and the matching speedo cable and clocks all of the same donor. It is fitted at the gearbox end and circlipped in place, however at the clocks end the cable will not connect.
I have rotated the shaft on the clock connector so the square feed goes into the clock but no matter how much force is applied the cable will not go far enough onto the connection to allow the plastic clip to engage. With the amount of force I don't think the plastic clip would hold it anyway.
Something is definitely not right....anyone any ideas please???
Check that the inner cable square end is definitely properly inserted at the gearbox end. Outer may be circlipped home nicely without the inner being engaged. You may just be able to turn the cable at the clocks end, wiggling and pushing it back down into the outer sleeve till it clicks home at the other end and 'shortens'.
