Super Spec Alternator Belt Removal
  • Please log in to reply
9 replies to this topic
#1 geordie40
geordie40
    Wheely good builder!
  • RHOCaR 18
  • 216 posts
  • Car type:Robin Hood Super Spec
Posted 07 August 2018 - 11:11 AM
Sorry if its a really stupid question but is the removal of the belt just a case of loosening the tension on the belt via the pulley (see photo)? I take it there is no timing etc to setup.
And I assume the cracks are in the belt are bad!!
Attached File  20180807_120643.jpg   590.52KB   0 downloads
#2 alanrichey
alanrichey
  • Area Secretary
  • 1,157 posts
  • Car type:Robin Hood Super Spec (Rover T16)
Posted 07 August 2018 - 12:02 PM
Wow, that does look bad  (Later:  maybe it's intentional ?).    And yes, all you do is put a ring spanner on the nut on the idler wheel and rotate it.   The wheel moves sideways and the belt will come off.  Dead easy.
HOWEVER.   Before you remove it make a drawing of the way the belt is put on.   Once you have it off it is easy to forget (ask me how I know)
Edited by alanrichey, 07 August 2018 - 12:04 PM.
#3 geordie40
geordie40
  • RHOCaR 18
  • 216 posts
Posted 07 August 2018 - 12:57 PM
I learnt the hard way as well so try and remember to take photos that way I can't draw it incorrectly either.
Don't think its intentional, just old age.
Ordered 1 from rimmer bros.
Another job on the "to-do" list which I never quite get to the end of!!
#4 Steve49er
Steve49er
  • RHOCaR 18
  • 253 posts
  • Car type:Robin Hood 2B GBS Superspec 00003
Posted 07 August 2018 - 03:49 PM
Rimmer Bros ??   :search:
Anything to do with RED DWARF ?  :nea:
Cheers  :drinks:
Steve  :lazy:
#5 bullfist
bullfist
  • RHOCaR 18
  • 250 posts
  • Car type:Super-spec
Posted 14 August 2018 - 09:55 AM
Do we have a part number for the belt?  (click/link?)  Looked at mine last night and it's just the same.
Drove it 36miles to work this morning, will I get home again?
As I guess these are original items probably over ten years old - has anyone looked at the timing belt under the cover too see it's state?
-steve
#6 AndyW
AndyW
  • RHOCaR 18
  • 258 posts
  • Car type:Robin Hood Super Spec, Rover 2L DOHC
Posted 14 August 2018 - 11:48 AM
Hi Steve,
You may recall I had to replace both belts on my Rover engine a couple of years ago (long story but broken shock absorber > flying spring hat > cut auxiliary belt > jammed around crank pulley > seized engine > snapped cam belt !!)
My car had been on the road for 8 years, although only done 3k miles, but the actual condition of both belts was ok. None of the cracking as seen in the photo above.
Parts I used for the rebuild were:
Cam belt - ContiTech CT803 (Eurocarparts p/n 325770465)
Alternator drive belt - ribbed 1152mm long. Rover PQS101590 (Rimmers) (Eurocarparts equiv p/n 202660085
Some Rover engines have a different alternator position, so it might be worth checking if the aux belt run and length is the same for both. Im not sure. My alternator is at top above the water pump.
Andy
RH Super Spec, Rover 2L DOHC, yellow grp, built & registered 2009, 2nd owner
#7 geordie40
geordie40
  • RHOCaR 18
  • 216 posts
Posted 14 August 2018 - 12:31 PM
I ordered the same alternator belt as Andy, I did find cheaper ones but wasn't sure so got original from rimmer's cost me £21.90 incl p&p.
Mine was also the type with alternator above water pump, I think the other type of belt depends on if yr engine was supposed to have air com. I think its on the list of engine numbers Alan compiled
Edited by geordie40, 14 August 2018 - 12:31 PM.
#8 bullfist
bullfist
  • RHOCaR 18
  • 250 posts
Posted 15 August 2018 - 01:13 PM
Plenty of options.
Interestingly carparts4less.co.uk is Eurocarparts (at cheaper prices) - probably because there is less choice and it's all home delivery.  Allegedly parts bought from carparts4less can be taken back to a Eurocarparts store.
-steve
#9 geordie40
geordie40
  • RHOCaR 18
  • 216 posts
Posted 15 August 2018 - 01:37 PM
Good to know, Eurocar parts always have discount codes so are carparts4less still cheaper?
#10 bullfist
bullfist
  • RHOCaR 18
  • 250 posts
Posted 16 August 2018 - 08:58 AM
IMO whenever I've looked, carparts4less have been cheaper than eurocarparts with discount.  I guess you're paying for the benefit of having it available immediately on the shelf.  When buying new brake discs, I actually found Halfords were cheaper - ordered in for collection from shop (same Pagid item), but this was an exception.  It pays to shop around.
-steve
