Power Drill - Any Recommendations ?
alanrichey
I've been using a cordless B&D drill for years, but am getting sick of the battery going flat at a crucial moment, the drill slipping in the keyless chuck when drilling holes in stainless steel and the lack of speed control. So time to upgrade !!
Tried to do some comparisons on Amazon but there are just too many and a lack of specific detail. What I am after is:
Multi-Speed
Corded
Keyed Chuck (Can you retrofit a keyed chuck to a keyless chuck drill?)
Hammer ?
Small as possible to get into awkward places.
Anyone any recommendations ?
  • Replies 33
B&Q have a great selection on display, so you cold get a hands on comparison, then hunt down the best price else where.
I have a 24v Dewalt, what a great bit of kit although large in size, came with 2 batteries so going flat isn't a problem.
The B & Decker one I have is next to useless, it was bought to wind up and down the caravan legs but it won't even do that more than 3 times.
+1 Dewalt....
Look out for daily deals on http://www.screwfix.com/c/tools/power-tools/cat830692
Also if you register with them and subscribe to there emails, you sometimes get vouchers and extra deals.
I was offered £10 of any purchase over £75 recently.
Worth looking out for weekly or daily deals on toolstation and screwfix if your not in a hurry.
OR look here and check out the comments: http://www.hotukdeals.com/search?action=search&keywords=drill
Sold Dewalt for over a quarter of a century & my "retirement presents" of 2 cordless are now beginning to die on batteries, but that's 10 years of hard work. Go for these if in budget -- machines usually come with drill, torque control, speed control, 3 gears ,forward/reverse & impact. Proper hammer drills ( which use the special SDS bits) are a lot bigger & need an adaptor with chuck to enable rotary drilling. Thinks that's enough of a sales pitch, just to finish will definitely replace with Dewalt when necessary.
If you are using cobalt drills on stainless the drill chuck will struggle to grip as cobalt is very hard/slippy.
Edited by florin metal works
Whatever you decide on, you can usually get two batteries in the kit. This is always the way to go.
Also li I batteries will last longer as long as not abused and over flattened as we tend to do. Getting that last little bit out of them.
They are designed to cut out at optimum charge time, that's the time to do it as working on with them will defo knacker them.
Guest Gargoil
Have changed a chuck on a drill before and it was easy to do. Have a look down the throat of the Chuck and if you see a screw/bolt head central to the chuck, thats the way it mounts. However, not all drills are the same, so check first. As with other members, Dewalt are good drills, get a drill with metal gears and cogs, plastic won't stand up to a lot of abuse.
Machine Mart clark contractor 24 volt ,2 batteries, multiple torque setting, 2 speed ,impact,reverse ,carrying box wait for a vat freeday what more do you want or require , it's only minor fault is it's a bit bulky .Had mine about 3 years its done everything asked of it which wasnot always fair mick :crazy:
