Crank And Cam Trigger Patterns Are For The T16 Engine
Guest red robin
Guest red robin
Would anyone know what the crank and cam trigger patterns are for the T16 engine? Adaptronic the manufacturer of my ECU are putting together a map to compare to the existing map so say set for running the car in and have asked for the info. without taking out the injectors can I assume they would be red band around 260cc
Is this a turbo engine? Most of us SS owners have got the naturally aspirated T16 so we probably cant help you much.
All the nasp engines have distributors, no cam sensor and a crank sensor on a two gap flywheel.
I believe the early turbo engines had a cam sensor on the inlet cam, but we just have a blanking plate.
After about 1996 all the engines went to wasted spark, had no distributor, no cam sensor, and used 4-gap flywheels.
I cant help you with the injectors as never taken them out. But Rimmer Bros is a good source of parts and info on the Rover engines.
Cheers Andy
