RHOCaR End of Season Bash
Come and join us for our Annual event  on 14th to 16th September
Camping, Family Fun,  Evening Entertainment and like-minded Company
Full Details and entry form here:
http://www.rhocar.org/index.php?showtopic=46637
Swirl Pot In Fuel Tank Issues
  • Please log in to reply
10 replies to this topic
#1 Jonnyround2003
Jonnyround2003
    Wheely good builder!
  • Community user
  • 378 posts
  • Car type:Robin hood 2b
Posted 19 May 2018 - 08:19 AM
I don't have one in my fuel tank I have the original ford Sierra fuel sender in the tank anyone had the same issues as me with fuel problems when cornering. Should I just change it for a land rover one with a swirl pot to sort it
#2 tractor
tractor
    tinckeritus
  • RHOCaR 18
  • 4,474 posts
  • Car type:zero zetec turbo
Posted 19 May 2018 - 08:25 AM
No brainer cheap fix at £35
#3 Matt brown
Matt brown
  • Committee
  • 288 posts
  • Car type:GBS Zero Turbo
Posted 19 May 2018 - 11:37 AM
Cheap yes but definitely not a quick or easy solution unless your tank is deep and then you need to find a way to secure it to the tank
GBS ZERO zetec turbo 253bhp
#4 tractor
tractor
    tinckeritus
  • RHOCaR 18
  • 4,474 posts
Posted 19 May 2018 - 05:16 PM
Always with the negativity Matt
#5 Matt brown
Matt brown
  • Committee
  • 288 posts
Posted 19 May 2018 - 06:09 PM
Not being negative just saying what work is required, I know if I was to do it again I would not use the land rover one.
A quick and easy fix for fuel surge or at least worth a punt is that foam you can get to go in your tank which helps stop the fuel sloshing around
#6 nelmo
nelmo
    Magazine Editor
  • Committee
  • 771 posts
  • Car type:GBS Zero
Posted 19 May 2018 - 09:35 PM
Someone on here recently tried the foam (Brumster?) and it didn't work.
Best solution is an external swirl pot and HP pump, like the current Zero uses.
#7 tractor
tractor
    tinckeritus
  • RHOCaR 18
  • 4,474 posts
Posted 19 May 2018 - 10:08 PM
just to put a spanner in the posts i found it fairly easy to fit a intank pump swirl pot and pump into the zetec tank cos my tank is alloy stainless steel is a bit trickier but do able and is a far better setup than having a low pressure pump feeding a swirl pot in the engine bay feeding a high pressure pump in engine bay i know of a few people who have suffered fuel vapuorisation due to engine bay temperatures  and GBS rave on about that setup cos it means more money for them  also that setup causes the fuel tank temperature to rise not good
Edited by tractor, 19 May 2018 - 10:19 PM.
#8 Dave R
Dave R
  • Moderator
  • 2,344 posts
  • Car type:2b passed sva may 05.pillars removed june 10. duratec power june 2012
Posted 20 May 2018 - 07:39 AM
i welded my swirl pot into the bottom of my rh stainless tank
tig welds ok, and didnt go boom
it could be done as a bolt in also i think with the right gasket material
its worth a look t see how bmw do it... the internal swirl pot is quite easy removed, just lift the back seat, and take out of tank
this is the pump i used, but threw away the rest.... even if its not useable, it may give you some idea's
i got the flanges/top plates laser cut for me, and have used viton rubber for the gasket
does not leak
#9 brumster
brumster
  • RHOCaR 18
  • 1,368 posts
  • Car type:Zero
Posted 20 May 2018 - 11:26 AM
Yep, exactly, foam cubes made no difference for me.
Matt does have a point though, implying to a new visitor that fitting a land rover pump is a "cheap fix" at £35 might be hiding a lot of detail - work to modify the tank or have an adapter plate fabricated, and so forth... it depends on the car/tank of course. I'm not savvy with 2B petrol tanks.
#10 theduck
theduck
    Chairman
  • Admin
  • 3,587 posts
  • Car type:Sierra S7
Posted 20 May 2018 - 01:59 PM
On the s7 tank, assuming you cut the hole accurately for the land rover unit you can use the OE rubber seal and it will push fit into the top of the tank.
It does need modifying still though to fit height wise.
#11 Longboarder
Longboarder
    Old Stager
  • RHOCaR 18
  • PipPipPipPipPip
  • 8,123 posts
  • Car type:New 111
Posted 20 May 2018 - 06:12 PM
To add to the mix I'm surprised at the anti two pumps and a swirlpot movement. There's space in the boot for all the bits. No idea why anyone would put them under the bonnet either. I use a cheap low pressure lift pump drawing through a cheap filter to fill the pot and a restricted return from the pot back into the tank. The HP pump draws from the base of the pot and then pumps through an injection filter  and via 8mm copper to the rail and back in 6mm copper to the pot. It all fits in a six inch deep space behind the boot where it keeps cool.
Looks like this and admittedly is fiddly to work on due to the space. Cost £70. I have had problems with blocked filters due to dirty petrol and have had to replace both pumps at the roadside. (But I carry spares)
Thought for the week.
Forget healthfoods. I need all the preservatives I can get.
