Robin Hood Wet Weather Hood
Guest Stephen King
Guest Stephen King
I have a new wet weather full hood for sale, surplus two requirements, can't get in with it on. It is black in colour and comes with the two aluminium supports. The doors are not available. £400
Regards Steve
I am not the most mobile guy so I just undo the first 3 poppers then Fidel to get them back on.
The other way is a zip to open one side in an L shape.
If you can't get in with a normal roof without doors fitted, even a Surrey top is no good for you.
You can keep dry at 70 but you will get wet when you slow down or pass a truck.
Guest Stephen King
Thanks for your advice, I've tried every which way to utilise my full hood without success so I'm going for the half hood option. I'm 68 and a biker from the age of 16yrs. so well used to getting wet. Once again thankyou for you help.
Regards Steve.
  • 1 month later...
Guest Stephen King
Full wet weather hood vinyl plus aluminium rails and side windows complete with windscreen and side panel hinges. £300
Very nearly new set. Fits my early Robin hood.
Steve
  • 1 month later...
