Rear Coilovers
Guest danny_samb
I lowered my arches by deceasing the bottom angle of the stainless back to the body. Be careful though the wings are different sizes. If you look at the tabs that hold them on you can reform the end bend of the stainless one tab further up at the back and two at the front then refit the wing moving it down so the new lowest tabs fit back to the bottom hole. You will need to redrill lots of holes and fit filler panels but you should get somewhere between 30 to 40mm lower without modifying the GRP arch.
