Heater
jaimo
I took just the heat exchanger & built it into a box on top of the gearbox bell housing ( using the foot-well sides as part of box ) the fan had one squirrel cage cut off to reduce size -- air in came via a "hoover" hose around 60 mm diameter which picked up fresh air from under the gearbox & hot air was fed to both foot-wells or the screen.
Guest Richard7
Saw your request and it reminded me that I was given a Mini heater by a RHOCAR member free of charge on the grounds that I never sold it. I never used it. I decided to build my own using the Sierra fan and cabin switch. So you can have the heater free of charge, all I ask is you pay the £6.50 postage or pick it up from Lincoln where I work or Saxilby.
