Megajolt 2.0 Pinto
Guest preeday
Guest preeday
Does anyone have any experience fitting a megajolt? I have one to fit, anyone got any info, pics or wiring diagrams? Would be help full.
Phil
Yep, done it
Wiring diagram is on Autosportslabs forum
You need Megajolt, Ford EDIS, Coil pack with Fiesta leads, Trigger wheel and VR sensor
You can connect just the megajolt to your computer by powering the jolt with a 9 volt battery
If you have trouble getting the computer to see the jolt look in computer properties and check which COM port the jolt is on then select the same port number on the jolt
Megajolt only connects on COM ports 1 to 10
On the Pinto making up a good steady bracket and finding somewhere to bolt it takes a bit of creativity
Edited by Snapperpaul
Yea. I want to dig a deep hole. My iPad is continually crashing. Just took me 4 attempts to sign in.
That's what I can do. It keeps crashing on me, so maybe I could crash on it. With a ******* big hammer.
