Couple Of Bits Wanted If Anyone Got Any
jaimo
little list of what i am needing just thought id ask on here before sourcing elsewere
1. lift of door hinges for weather gear
2. mini wiper motor securing ideas [as just hanging]
3. pinto oil spray bar
thanks guys
That's the fellow, but is easy enough to make your own.
Like said earlier a massive "P" clip works
Edited by Ian & Carole
I got some lift of hinges, had to cut them down though because of the size. Can't remember what the sizes are but they work fine with my doors :)
I'll grab some measurements tonight :)
P.S. I ordered more than I needed as their website said they came as single hinges but the packs were double. Guessing they meant single door...I'll dig them out too
Edited by WallerZ
did you find the hinge sizes and where from wallerz
Hi mate,
Sorry this took forever to get back to you. Very hectic period at work and home. I can't even begin to figure out where I put the spare sets but for that price (below) they're silly cheap.
http://www.ironmongerydirect.co.uk/products/hinges/door_hinges/4095/steel_liftoff_hinge__75mm/988591
Here is the hinge I got. I put the 'sleeve' on the windscreen frame and the 'pin' side on the door/wind deflectors. To reduce weight (it all counts) I cut the 'sleeve' ones in half so it was literally the sleeve across. I'll try find a picture or think there might be one on my blog already.
I just sprayed these over quickly and then had 2 rivets to hold them to the frame. Worked well although would work better one the other side.
Hi. The male prt usually fit the a post to stop the male dingle dongle dropping out as does happen after time.
You will be fine as long as you keep the pins clean and lubedhth Ken.
