Weber 40 Dcoe Pinto Hoses
Guest alexpink
Guest alexpink
I have a 2.0 Pinto for my Sierra 7, and twin Weber 40 DCOE carburettors for it. However, having never done a project like this before, I have no idea where to obtain hoses for the connections, nor how they should all be connected.
If anyone could point me towards somewhere from which to obtain these hoses, and possibly a throttle linkage? I have the Pinto hiflow inlet manifold.
Thanks!
Alex
If it is how to pipe up the webers the pic in this http://www.ebay.co.uk/itm/TWIN-WEBER-CARB-DCOE-40-ON-FORD-PINTO-MANIFOLD-ESCORT-CAPRI-/130976209590?nma=true&si=o8lEj8hcDnNm5ekt79mchtZHKiA%253D&orig_cvip=true&rt=nc&_trksid=p2047675.l2557 listing shows you how.
Just need fuel line from fuel pump.
Depending what pump you intend to use you might need a pressure regulator between pump and carbs.
Guest alexpink
Great help thank you. Is it only the fuel pipe that needs to go into the carburettors, or are there more, like a vacuum? Looks like there's a hole for one :s
Depending what your existing setup is you may need to replumb the engine breather pipe into a catch tank instead of the inlet manifold (modifying the non return valve) and if you have a servo that will need to connected to a runner on the manifold.
