Design Weights
Guest Ianz
Hi all
I'm filling out my form for SVA test and I need to know the design weights
for axle 1 & axle 2 on Robin Hood series 3A
By the way what address do I send the form to?????
Cheers Ian
Guest ant.b
hi ian
axel 1 = 450
axel2 =600
gross =1050kg
address, sva section , vosa ,91/92 the strand ,swansea, sa1 2dh
mine is a 2b but think yours should be similar??
cheers ant :D
Ant
Thanks for the quick response,
I've just found the address for Vosa in small print on the notes
for completing the SVA form!!!!!!!
Must get my eyes tested.
Anyways I got my Vin number saturday,I'm posting my SVA
application today,depending how quickly Vosa respond I hope
to get the SVA done this month......on the road by April.
On a wing and a prayer may get to Detling in my Hood!!!
Cheers Ian
:D :D :D :D :D
I've just spoken to Richard at RHSC and he does'nt have a clue
what the weights should be
he said that I' ll have to "take it somewhere to get it weighed"!!!!!!!!!!
:angry: :angry: :angry: :angry: :angry: :angry: :angry:
Thanks for those weights.
It certainly helps ,now I can get my SVA form in the post!!!!!!
Cheers Ian
:D :D :D :D :D
PS : Do I put on form your actual weights,without driver
but rounded up say 350 axle 1 & 400 axle2?????
Guest Trevor 2B
For info my 2B was 370Kg on the front and 340 kg on the back with a 1600 pinto/stainless panels.
But remember you have to add 75Kg per person weight to that.
  • 3 weeks later...
Design weight is the maximum static weight that the axle is expected to see.
The brake test uses this info.
If the car + fuel + passengers + luggage can come out to more than the weight you have declaired then expect a fail.
