I Just Cant Stop Tinkering
tractor
the st170 also has a different engine mount set up to the standard zetec the oil filter side is the same but the exhaust side is totally different but I had a stroke of luck when I was first fitting the zetec into the 2b I brought some engine mounts off of flebay they were advertised as zetec to rear wheel drive but they didn't fit so got slung to the back of the garage turns out they fit the st170 not had some good luck for a while
oh crap got quite a bit ow wiring to do tomorrow the vvt controler has to be connected to the tps senor crank sensor and cam sensor as well as two ignition lives and earth hope its worth it
I would be very interested to see the map. What parameters does it use? Revs. Load? Does it alter ignition timing or just cam timing.
I have an old S60 VVT map for an ST170 which is interesting. Yours for comparison if you want it (and if I can find it!).
