Pinto To Zetec Conversion 2B
tractor
Guest Tim Norman
Can you not mount the rear wings lower so you don't have the huge gap between the wheel and arches?
You will need to make a new infill panel but it will improve the look of the car no end.
That's why Florins rear 'guards are hub mounted --- if we could have got minilite style wheels in a bigger diameter it would look better though.
Guest Tim Norman
You won't have any ground clearance if you drop it 2" You will also find your brake are not as effective as their "effective" leverage will have been reduced with the larger diameter wheels.
