Ballist Resistor
Guest fatherhood
Yes, looks like a main 200 amp type fuse. It should have a rating on it somewhere though - perhaps underneath ?
(edit - Then again it may not be stamped as this would affect the rating and probably lower it. If it's anywhere, it would be off to one side and not in the main flow path)
If you can measure the width and thickness of it as accurately as possible and the length of the narrow section, I could hazard a guess at its rating for you.
Or you could look for a similar sized fuse in your main car and compare it to them.
But, definitely not a ballast resistor.
Simon.
Edited by Simon B
Yes. That link you posted Ian looks more like a ballast resistor than the OP's picture which looks more like the fusible links that I have seen on my Seat near the main battery.
I still think the original picture is a heavy duty fusible link though.
Simon.
