Super Spec Exhaust
Guest toma94
Guest toma94
she's alive and better than ever!
also with an original caterham silencer fitted
there she is with my friend's caterham roadsport 125
  • Replies 54
Guest toma94
well it's easy to have a good weather here in italy ahaha
i kind of wonder how a british man had the idea to build such a type of car ahaha
Have you kept the catalytic converter with the new exhaust ? And have you read the post on my diagnostic software for the Superspec. I only mention it as we have yet to find a Superspec where the lambda sensor is working properly.
Guest toma94
Nope, the catalytic converter was the first thing i trashed
i know that you must have two lambda sensors in order to make them work correctly (one in the manifold and one near the silencer), but my car came with only one lambda sensor and no space for the probe in the manifold, so i guess it never worked anyway
No, on the standard Superspec with the Rover MEMS 1.6, the ECU supports only a single narrow band sensor at the end of the downpipe to control the fuel/air ratio. The cat is there to clean up the residual hydrocarbons and is essential in the UK if you want to pass the emissions test we have to have every year. I assume that isn't the case in Italy ?
If the single lambda sensor isn't working then the car runs in 'limp-home' mode with a fixed, slightly rich, fuel/air ratio. Luckily this makes the car run rather better than when the sensor is working :)
Guest toma94
Hello Alan
let's say that emission test is not so strict here in italy...
Mot has to be done every 2 years and they just check lights, brakes and security stuff
emission test is mandatory too, but they close an eye over strange cars
Just a random question
i saw a few robin hoods with mk indy's body
are they easily swappable?
No idea, I'll leave that for someone else to answer
Guest toma94
by the way i bought a pair of used doors off ebay
i really liked the look of them and from the measures i think they were made for a robin hood
we'll see as soon as they arrive
  • 5 months later...
