Sierra Rear Drive Shaft Cv Boots
Guest Ophidr
The picture's not that clear but they don't look like the original boots. If they're the push in type shafts at the diff end, the original boots are integrated in to a metal can that's staked around the joint. When they split, people cut off the old rubber boot and just replace it with the universal type boots. If you want to save a load of mess and dismantling, get the stretchy boots that you can slide over the joint on to the shaft using a cone. They look like they won't stretch sufficiently but they do in fact go on.
Luckily for you maybe, I have a cone and I'm in Tamworth.
