Robin Hood 2B+ For Sale
Guest christcp2
Guest christcp2
2003 Robin Hood 2B+
I am selling the car because since I have bought it 2 years ago I have only used it 4 times. I intended to take it on the track but only used it locally on the road and took it to the Naphill car show.
It has been sat for one year with no use and although all electrics work and the brakes are not locked the engine turns but unfortunately does not start which is hopefully fairly simple to fix and just due to being sat for too long.
2.0 Ford Pinto engine.
Twin Weber 40 carbs.
New Besteck ignition kit fitted by previous owner: Distributor, Coil, Amplifier.
Toyo alloy wheels.
Mountney 11" steering wheel.
New Premier wiring loom fitted by previous owner.
Interior refurbished by previous owner, including: ETB gauges: Speed/Odometer; RPM; Fuel; Water temp; black carpet, Cobra Monaco Pro seats with TRS four-point harnesses, new dash with Bright Six lights and boot release, Fog light, radiator fan and start switch (not connected).
30 litre tank.
Leather roof and doors.
Included:
Dust cover
Lockable clamp
Fire extinguisher.
Previous owners 3.
Corrosion on headlights which you will probably want to replace, paint scratch on the bonnet which was there when I bought it and minor stone chips on paint work from driving on country roads.
Priced accordingly at £1200.
Car is in High Wycombe. You can contact me at christcp2@yahoo.co.uk or 07971 808213.
