"cheap" Chinese Gauges
geordie40
I bought some similar gauges via america as they were cheaper than many outlets over here, and they work fine with sensors supplied. But beware, I had to pay import duty on them, which was around £18,if I remember correctly, so take this into account.
don't mean to thread hijack so can start a separate one if necessary but was looking at these https://www.ebay.co.uk/itm/B332-3-in-1-Car-Vehicles-Gauge-Voltmeter-Water-Temp-Oil-Pressure-Sensor-Kit-Set/153176052522?epid=11023619697&hash=item23aa01132a:g:FFYAAOSwLNpbl7fI:rk:28:pf:0and wondering how they connect up.
Volts is easy i guess just connect to battery.
Temp i assume needs a specific sender which looks like it's included but is that likely to be a standard size that would fit the pinto?
Oil pressure? how does that connect up.
thanks
Looks like you get the sender as well (large round brass thing in pic), It's electronic sender not mechanical so you only need a wire rather than a capillary tube with the oil in.
I assume thread sizes are standard
Edited by geordie40
