What Make Front Suspension Parts
Guest mdav1970
Guest mdav1970
Can anyone tell me what make the lower front ball joints are from, the ones with the 3 bolt holes attaching them to the wishbone. Also the lower front shock bushes.
Thanks,
Mark
If yours is the New 3 then I believe it has outboard coilovers and a different lower arm to the 3A. My 3A uses the standard Sierra TCA with integral ball joint. Can't help with what your ball joint is, sorry
Rob
My wishbone conversion uses an early Astra balljoint. The taper is identical to the Sierra hub taper.
https://www.ebay.co.uk/itm/VAUXHALL-ASTRA-Mk1-82-84-OPEL-KADETT-D-82-84-NEW-LOWER-BALL-JOINT-QSJ877-/142373020228
As Stuart say, a picture would help a lot
Searching Ebay, this one looks promising
https://www.ebay.co.uk/itm/LEMFORDER-Supporting-Joint-Ford-galaxyii-MONDEO-IV-S-MAX-and-Volvo-Front-2-Pcs/292423175053?fits=Car+Make%3AFord&epid=1446141102&hash=item4415c78b8d:g:pmMAAOSw8d9U0kYC
There may even be a part number stamped on yours.
Edited by Big Jim
Hi Bob,
if you search back through the forums someone posted a fix a whille ago.
My advanced years prevent me remembering who or when.....off for a nap now.
On chrome i have used the "photobucket hotlink fix" extension
Edited by Bob Tucker
