Clutch Cable Fitting
Guest gazza1591
pedal box end. It needs to go on the outside of the pedal box before it goes through the metal so it is against the outer cable cover. My cable has a big plastic lumpy bit at the end of the outer cable, the washer goes there. So you need to take the cable off the yellow quadrant again push it back through so it is now loose in the engine bay, put the washer on and then reassemble.
hth
