S7 Rear Brake Line Help
Guest gazza1591
Guest gazza1591
Anyone with an s7 able to take some pics of how there rear brake lines are run please struggling to find best route for them, I have ran the one from the front to the back then it goes to a T piece to feed left and right at the rear. From the T piece I have to hard lines which go to a flexi pipe the to a bracket it's from this bracket to the caliper flexi I can't work out any pics would be good
This is my RH rear, there is a flex that comes from the T piece that you can see on the rear bulkhead connecting to the hard pipe at the bracket in the centre of the picture, then the hard pipe continues to a connector fixed into a suitable sized washer that is welded onto the rear wishbone just above the seam, then the flex is connected to this.
Edited by Big Jim
