Petrol Tank Required.
Guest Pauljordan
Guest Pauljordan
Does anyone have a petrol tank for sale? Just dropped mine out and found out that previous owner must have had a leak on the sender unit gasket so had just tightened the bolts down too tight, the one of the bolts has ripped the stainless tank were it was welded on!!! Now I've got a leak......
PJ
Can't find the picture.... you need to bust out re other studs and it needed clean up holes with drill. take a large washer, So the the hole the same size as sender, and outer larger than the existing stud layout... cut a chunk out of washer and drill and tap the sender bolt holes.. fit studs to washer.
Thread into sender hole and without dropping it pull studs up through tank .....simples
Guest Pauljordan
Thanks guys, looks like I have a challenge for tomorrow. I will let you know how I get on.
Chris, rad is out and new mounts been made today. You're a jinx. Noticed master cylinder has a weep!!! Are well kit car fun I suppose!
Never a dull moment.
