Trailing Arm
Jez Morton
Hi Jez,
Depending how the tap has broken you should be able to break it up and remove with a hammer and chisel or punch, It may take a bit of time but worth the effort then carefully drill and re-tap if possible or drill out and maybe put a nut on the back.
Regards Martin.
Hi Martin I did find a way to get it out, I used a Waltons broken tap extactor. It was jammed because it was in a number of pieces so they locked each other when you tried to turn it.
So thankfully trailing arm no longer required, cars all ready for Stoneleigh.
