Advice On Tappets/valve Clearance Setting
magh
Just some cheap classic 20/50 from Wilkos which will do a couple of miles and will dump it for a better brand. I dont think the oil had much to do with it really I suspect the frustration and heavy right foot with the thought of it will break or make it lol.
Guest IanSouthLincs
Run it with the rocker cover off for a few seconds and double check you have oil coming out if the spray bar, they are notorious for blocking up
Guest IanSouthLincs
Also, what cam is in there? If you’re using a higher lift cam I’m afraid they do rattle a bit, stronger valve springs does help but it won’t go away co,mpletely.
