Zetec Black Top With Motorbike Carbs, Will It Pass An Iva
Guest James
No idea but why bother? The Zetec is all ready for FI - why put carbs on?
Do a search on here for threads talking about carb problems - one of the most common topics. I realise there is a certain, misty-eyed nostalgia for carbs but for the difficulty so many people seem to have with them, I'd steer well clear.
Guest lotusPaul
James
You will get as many negatives as positives to this question, the answer is yes. Problem tho is you really need it RR setup. You need a programmable ignition,and it needs to be setup on the ball. Then going to the carbs,again need to be flow balanced and jetted for your application,I must admit I'm a dcoe fan. Either way it's a trip to a RR,kind of begs the question to be honest,why go to all that trouble and not fit bike injection? I looked on das bay before posting this,bike injection rack was buy it now 100 pounds. Needs cutting to fit but that's all on utube. Fitting efi is getting cheaper these day's.
