Supercharger Boost Control
  • Please log in to reply
No replies to this topic
#1 DanE
DanE
    Electrickery master
  • RHOCaR 17
  • PipPipPipPipPip
  • 6,427 posts
  • Car type:ssc
Posted 06 September 2017 - 05:31 PM
Started a new project today to try and tame the boost when trying to cruise @70mph. The idea is using a Mac 3port solenoid boost controller and a mini vacuum pump. The plan is when I switch to economy map it will switch the valve over so the plenum vac line to bypass valve is closed stopping boost pressure at the same time the mini vacuum pump then pulls the bypass valve open thus stopping boost. Hopefully then I will be able to drive at 70mph without boosting to warp speed all the time... Will update when I have made and fitted it all.
Ssc stylus with a supercharged zetec 242bhp and 253ft lb of wheel spin.. Bhp costs money, loads of it ! :shok:
