Wiper Gear
  • Please log in to reply
8 replies to this topic
#1 DAVE1954
DAVE1954
    Wheely good builder!
  • Community user
  • 131 posts
  • Car type:robin hood 2b
Posted 29 August 2017 - 06:10 PM
Hi just bought a Sierra wiper motor and linkage, I've just cut it down ( modified) I've not got wiper arms , do I use Sierra arms or are they too long. Cheers. Dave
#2 tractor
tractor
    tinckeritus
  • RHOCaR 18
  • 4,184 posts
  • Car type:zero st170 on megasquirt ms3x
Posted 31 August 2017 - 03:59 PM
think its the mini wiper arms people use
#3 wanderer
wanderer
  • RHOCaR 18
  • 168 posts
  • Car type:2B, titanium super spec
Posted 31 August 2017 - 04:54 PM
are you fitting chrome or black arms
#4 IanS
IanS
  • RHOCaR 18
  • 466 posts
  • Car type:exmo
Posted 31 August 2017 - 06:23 PM
I cut down and welded the sierra wiper gear and fitted cut down sierra arms.
I bolted cut in half wiper blades to the arms which have lasted 20 years.
#5 DAVE1954
DAVE1954
  • Community user
  • 131 posts
Posted 31 August 2017 - 09:40 PM
Hi thanks for reply, I've yet to buy wiper arms so I'll go for the mini option if that's easier, I've bolted, the wiper gear arms works fine, but I'm going to weld them because they look bodged. Cheers. Dave
#6 IanS
IanS
  • RHOCaR 18
  • 466 posts
  • Car type:exmo
Posted 31 August 2017 - 10:10 PM
The Mini wiper arms will require modification to fit the sierra spindles.
Mini arms are push fit to parrallel splines whilst the sierra arms are held on tapered spinbles by a nut covered by a captive hinged cover.
Both solutions work but both require some adaptation.
#7 wanderer
wanderer
  • RHOCaR 18
  • 168 posts
Posted 31 August 2017 - 10:15 PM
I have fitted mini arms by drilling the centre out and fitted a domed chrome nut to fit a 14mm spanner and fitted 9" wiper blades hth
#8 DAVE1954
DAVE1954
  • Community user
  • 131 posts
Posted 19 September 2017 - 01:06 PM
Hi wanderer. So you drill out the mini wiper arm , and fix a nut Sierra spindle, is it a case of wiper holds by the nut jamming it, or are the splines the same size, is it the classic mini arms you used. Cheers. Dave
#9 wanderer
wanderer
  • RHOCaR 18
  • 168 posts
Posted 19 September 2017 - 02:22 PM
think i used classic mini arms but had to drill out the rivets and shorten i got 9" blades from tex drill arms slightly bigger than ford spindle and the arms fit the splines when tightened.tried to add photo but unable to on this site sorry
