Rwd Ecoboost
Guest lotusPaul
Guest lotusPaul
Has anyone had any experience or knows anything or anyone that has put an ecoboost into a rwd application.
I seen on web that Caterham have one courtousy of Ford, 1.6. So im thinking the 2.0 turbo ecoboost should too.
Web search doesnt give much away, any ideas?
Guest lotusPaul
Electronics isnt a issue just yet. More concerned with can it fit to a Ford rwd box, mounting issues etc. For these reasons im heading towards the larger capacity versions as per mustang.
Guest lotusPaul
Thanks Duck. I think you may be correct there. USA sites indicate the same. There are companies that supply harness and controll modules to fit to rwd, hence my reply above. A bit pricey but its new tech ish.
Sounds like it can be done tho, interesting.
Thankd
Guest lotusPaul
Its the box i have not the engine.ecoboost is new tech. All about forging ahead with the new gear.
I could stick in an all ally LS engine,but thats easy option. Trying to break new ish ground. Esspecially if it will cost same as a turbo zetec,
