Fitting Fibreglass Seats To A 2B
Guest winmoz
I am in the process of replacing the seats in my 2B. I am looking to mount the seats direct to the floor as I want to be as low in the car as I can be as the old seats put my eye line level with the top of the windscreen, which is a bit annoying.
On the current set up the harness mounts are attached directly to the runners (which I am going to get rid of). Any ideas as to where i can get some mounting brackets to replace them? I am currently toying with the idea of simply cutting the old runners up and using them as mourning brackets.
cheers,
s
on mine the bottom harness mounts are bolted to a couple of short bits of angle that is bolted to the floor with a spreader plate underneath...
i have a feeling that its also attached to the angle iron underneath that picks up the handbrake cable outer....
