Sierra Rear Suspension Outer Bush Bolt Specs'
GambolGold
I can feel a SORN coming on. 😷
They must have reached the end of their usefulness relatively recently as the MOT man did not list them - though they are exposed - and he did list the inboard front coil-over bushes which you can only see by taking off the bonnet.
Thanks Richy and everyone else.
Seeing that I need to remove the arms, I will use a press. Using a press is it then just as straight forward to use the black rubber bushes, or will they still be really difficult to fit? (should I still buy the poly bushes, though I'm using a press? )
When I built my rear suspension I used POWERFLEX bushes part no's as below
Rear trailing arm outer bush kit (PFR19-110)
Rear trailing arm inner bush kit (PFR19-111)
Note! Bush kits supplied with new 12mm bolts and nylock nuts.
Much easier to fit than the ford bushes and will last longer,
Martin
