S7 Rear Coilover Length
Guest alland3851
Guest alland3851
I am considering changing the set up on the rear of my S7 from spring and dampers to coil overs. What open length would I require for the change and what spring poundage would be suitable.
Any advice would be appreciated.
Guest alland3851
Hi guys, thanks for the replies.Thanks steamer for the pics, that looks like exactly what i am trying to do. I suppose that if i did not have the spacer between the coil over mounting and the angle bracket at the top I could use a longer unit. What make of coil over are you using and what springs do you have on them ?
Another photo, a bit out of focus! Spacers added either side of the top shock mounting to stop end float. Reinforcing plates are fitted to the outside and inside of the boot to sandwich the weak stainless side panels to give added strength and stop flexing.
