Ford Sapphire Dohc Starter Motor
  • Please log in to reply
5 replies to this topic
#1 jelleyhead
jelleyhead
    Wheely good builder!
  • RHOCaR 17
  • 112 posts
  • Car type:super spec 2ltr dohc 8 valve
Posted 19 April 2017 - 05:55 PM
Hi all i am looking for a starter motor as mine has given up . Engine was from a j reg ford sapphire 2.0 dohc if anybody knows were i can get one or has one they don't need.
#2 tractor
tractor
    tinckeritus
  • RHOCaR 17
  • 4,160 posts
  • Car type:zero st170 on megasquirt ms3x
Posted 19 April 2017 - 10:21 PM
just take it off and get it repaired much cheaper
#3 jelleyhead
jelleyhead
  • RHOCaR 17
  • 112 posts
Posted 20 April 2017 - 01:24 AM
Hi the starter is ok it's the solenoid thats packed up the wire that goes to one of the terminals has broken off in side i did try to fix it.
I have had a look around but you can't get just the solenoid on it's own.
You have to buy the starter motor the ones i found seem to be different to the one on the engine.
Am not sure of anywere in my area that fixes starters?
#4 cb750
cb750
  • RHOCaR 17
  • 1,154 posts
  • Car type:3A
Posted 20 April 2017 - 06:10 AM
As Tractor says, have a look in your area for a repairer, I had my starter reconditioned at a local place at a good price
Must read your last post more carefully! If you search for dc motor repairers you may find one.g
Edited by cb750, 20 April 2017 - 06:13 AM.
#5 Smig380
Smig380
    Builder
  • RHOCaR 17
  • 30 posts
  • Car type:GBS Zero 2l Pinto
Posted 20 April 2017 - 08:28 AM
I have a spare 800w starter for a Pinto (ex Sierra) with a Type 9 gearbox if that's any use. Free if you come & pick it up.
#6 florin metal works
florin metal works
    Hants & Dorset Area Secretary
  • Committee
  • PipPipPipPipPip
  • 7,054 posts
  • Car type:2B+
Posted 20 April 2017 - 08:36 AM
The starter solenoid will quite happily do without a turn or 2 on the windings.  Take one or 2 of the coil to give enough slack to re-solder & also clean all the contacts/remove gunge while in there.
Re- wired/cleaned Florin's starter solenoid 5 years ago after it failed & still all good.  ( crossed fingers/ money spider around head/4 leaf clover picked)
