Fitting The Wet Weather Gear To A 2B
Guest max&sarah
Guest max&sarah
Hi ,
I have just purchased a new wet weather hood for my Robin Hood, does anyone have any instruction, photos or anything so i can work out how to fit it ?
thanks ,
Max
Has the car had wet weather fitted before? If so then fit the studs to the hood to match. If not then first make sure the screen to back panel is the correct distance (can't remember it but no doubt someone will) then either wait for a very warm day or get the garage very warm so as to be able to stretch the hood in place. Take your time marking out where to put the press studs. I would recommend fitting an awning rail to the top of the screen and sowing awning tape to the front of the hood as using press studs never seals and you get lots of water in.
might be worth putting your location in your profile, there could be some one near you who could pop round and give you some advice / help. If you are coming to Newark show come and see one of us and have a look how we have done it
  • 4 months later...
Guest karif2800
Hi, this morning is arrived the wet weather gear dorm gbs. In the package I've not found the door hinges and something to fit the subframe to chassis. Anyone have a pictur of these plates that, I presume, are fitted near the rollbar. I'd like to have some picture to know how I can make a support for the subframe. Thank you very much for help
