Mini Wiper Motor Wiring
Guest Tim Norman
Guest Tim Norman
Here's one for you clever sparky people out there.
I am replacing the single speed mini wiper in the Stealth Kitten with a twin speed. In the Kitten it runs off a rocker switch that also runs the wash wipe function.
I have separated that function so the wash is on a separate button.
Now I need to make the wiper work on a new rocker switch.
My question is how?
On the single speed there was just two wires going to the motor that made it work, so what do I need to add to energise the third wire on the motor?
I have Nigel's drawing of the sierra wires to mini loom so I know which wire is which it is at the other end I am struggling with!
Tim,
When the switch is turned off, power to the motor to park the wipers comes from pin 4 (green) at the wiper motor via the park cam switch in the motor which connects to pin 2 (brown/lt.green) from the motor to pin 5 at the switch, as pin 4 and 5 are connected when the switch is off then power goes from pin 4 at the switch to pin 5 (red/lt.green) on the motor making a circuit until the cam switch breaks the contact when the wipers park.
Hope that make sense
Les.
Edited by Les Welsher
Guest Tim Norman
Les Its is the other end at the switch I was after. On my piccy I assume pin 4 is where the power comes in from my fused switched live and also goes out to the motor.
Its is in a Reliant Kitten so there is no stalk. In the Kitten the original motor only had one speed and no park. Not bothered about intermittent. I am replacing the Oringinal dash with a modified Mini Dash that now looks like this
Edited by Tim Norman
try this one
Fused switched live to pin 2 on switch gives power to pin 4 on switch and to motor when switch is on position 1, pin 2 gives power to pin 1 for fast speed when switch is on postion 2.
Les
