Brake Discs
Stewart
Need a new set of front discs,using standard sierra discs at present have been told it would be beneficial to upgrade to larger diameter.What do I need in discs and I presume new callipers,what is the cheapest options and how difficult are they to fit. (ZERO 2Ltr Pinto )
Euro car parts can supply standard size vented PAGID disks, which are the best I have found.
Add a set of MINTEX 1144 pads, & you'll be done.
The braking limit will generally be the tyres, not the braking system.
Can you lock the brakes at present?
Are you going to spend every weekend on track at speed? then maybe. A lot of extra money to stop an over braked car for road use.
Nice if you can afford to buy " bits" to look at. Just my opinion.
