Zetec Alternator Dimensions
1186497
Evening all, Just looking at which alternator to fit to my blacktop 2b conversion and seem to have quite a bit of room left which i'm thinking might mean I can put the standard blacktop one in (already have the bracket). Does anyone have the dimensions ?? of this so I could check prior to buying on eBay as don't have any local scrapies! Thanks Simon
Guest Sevenheaven
Don't have the dimensions but I am running the std on my 2B Zetec with room to spare, make sure you get the 3 pin plug with it and link the green wire to the battery to excite the regulator otherwise you get no output from it!
Thanks Alan. Got one from a ford Ka which seems to fit the alloy bracket that was already with the engine. Now just the water pump to sort! Cheers for the advice on the wiring, I may well come back to you on that when I get sorted.
