First Shakedown Run In The Zero
#1
Posted 10 April 2011 - 09:13 PM
I must say I had a few issues though. Firstly the engine is running very hot at 100-110 degrees and the fan is constantly on. However I did notice some popping and rough running on decelleration so this could in part be down to timing. The car has yet to visit a rolling road. Secondly the adjustable suspension seems very crashy over our far from perfect road surfaces. Does anyone know how to adjust the ride height of the gaz shocks? And thirdly the flat bottomed steering wheel isn't centralised. Do I alter this myself or should I take the car and get it tracked even though it doesn't pull left or right?
Any advice welcome.
Apart from these small issues I really enjoyed the drive and can't wait for Barkstone.
Jason
#2
Posted 10 April 2011 - 09:24 PM
bike carbs will pop a bit on over run, but do get the carbs set up as soon as pos in case to lean.
#3
Posted 10 April 2011 - 09:31 PM
As soon as funds allow I'm going to book the car in with Russ at Torque Tune as he is only about 25 miles from me.
Jason
#4
Posted 11 April 2011 - 12:12 AM
To adjust the shock bump & rebound, there is a small knob at the bottom of the shock. Unscrew to reduce damping, screw in to increase it. Try 2 clicks at a time to start then fine tune by one.
#5
Posted 11 April 2011 - 12:24 AM
Also with regards to damping, if my suspension is bottoming out over bumps as it seems to be, do I need to increase or reduce the damping and rebound?
Jason
P.s. Sorry if this is in the wrong forum area.
#6
Posted 11 April 2011 - 08:27 AM
#7
Posted 11 April 2011 - 10:35 AM
Thanks for the advice.
Jason
#8
Posted 12 April 2011 - 05:38 PM
Jason
#9
Jason
#10
Posted 12 April 2011 - 06:14 PM
#11
Posted 13 April 2011 - 07:55 AM
The Tyres are the standard Yokohama ones that come in the zero kit and from memory they are 205x50x15. As for pressures I need to double check, but I usually run at about 20psi. Is this sufficient for a lightweight car such as the zero?
Regards,
Jason
#12
Posted 13 April 2011 - 08:05 AM
#13
Posted 13 April 2011 - 10:47 AM
Jason
#14
Posted 13 April 2011 - 11:29 AM
#15
Posted 13 April 2011 - 01:45 PM
Jason
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
