Fitted my bike carbs today and they are leaking from the t If I change the o rings will it cure it ??
Bike Carbs Leaking
Started by greavesy7, 18 Apr 2012 09:57 PM
3 replies to this topic
#1
Posted 18 April 2012 - 09:57 PM
#2
Posted 19 April 2012 - 07:58 AM
Hi are they leaking from the breather for the float chamber?
Best to check the fuel pressure going to the carbs, I ran 2psi to the bike carbs on my pinto engine zero. The pump on the engine will produce about 7psi as standard and this could be too much for the carbs to handle.
I also had problems with the fuel pushing past the needle valve in the float chamber until i lowered the fuel pressure with a pressure regulator.
HTH
Marcus
HTH
Marcus
Urlhttp://www.flickr.com/photos/opentrack-track-days/8627056061/URL
#3
Posted 19 April 2012 - 11:50 AM
its leaking on the t Joint that feeds the 2 carbs. im using the bike fule pump as i was told the engine pump runs at low pressure but high volume
#4
Posted 19 April 2012 - 08:00 PM
Have you got a photo??
Feeding fuel into the air/water pipes is a common mistake.
2L stage 2 Pinto, Kent FR32 cam, Lumenition ignition, ZX6R bike carbs
GOOD HEALTH IS MERELY THE SLOWEST POSSIBLE RATE AT WHICH ONE CAN DIE
For all your crystal and holistic therapy needs click here
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
