RHOCaR End of Season Bash
Come and join us for our Annual event  on 14th to 16th September
Camping, Family Fun,  Evening Entertainment and like-minded Company
Full Details and entry form here:
http://www.rhocar.org/index.php?showtopic=46637
Drive Shaft To Prop Shaft Linkage
Differential
  • Please log in to reply
7 replies to this topic
#1 Paul94
Paul94
    Getting there Builder
  • Community user
  • 60 posts
  • Car type:Zero
Posted 07 August 2012 - 12:41 PM
Another simple question from someone without an automotive entering background....
Having installed both rear drive shafts, I can understand why they can (almost) independently rotate. This is the main purpose of the differential and allows one wheel to move at a different speed to the other so you can go around corners. What I didn't expect was that turning the prop shaft did not turn the drive shafts. It rotated freely and seemingly had no effect on the drive shafts. I was expecting some sort of direct linkage.
Is this normal, or do I have a problem with the diff?
Paul94
#2 agent_zed
agent_zed
    Wheely good builder!
  • Community user
  • 2,892 posts
  • Car type:2B with double wishbones
Posted 07 August 2012 - 02:08 PM
if you have both wheels on the floor and push it forward and back the prop should turn!
If you have one wheel off the floor and you turn the prop then the wheel off the ground should turn.
If it don't then something ain't right?!
hth
#3 Grim
Grim
    What do you mean by 'wash'?
  • Moderator
  • 3,698 posts
  • Car type:Fully stainless / green 2b, standard 2l pinto, self dismantling
Posted 07 August 2012 - 04:00 PM
did the diff and shafts come as one? is it physically possible to put a small shaft in a larger hole? (open question)
#4 snotfart
snotfart
  • Community user
  • 268 posts
  • Car type:lolocost irs sport 3.9 V8
Posted 07 August 2012 - 07:20 PM
great film,thanks for posting.
if experience,skill and ingenuity fail
try brute force and ignorance
you never know it might just work
http://s914.photobuc...ac342/snotfart/
#5 zoomzoom
zoomzoom
    Scruffy stig
  • RHOCaR 18
  • 1,014 posts
  • Car type:Zero 7 Built By Bear Power
Posted 07 August 2012 - 07:53 PM
Turning the prop should turn at least 1 of the drive shafts, check the drive shafts are fully inserted
Posted Image
#6 Paul94
Paul94
  • Community user
  • 60 posts
  • Car type:Zero
Posted 08 August 2012 - 06:55 AM
Thanks for the U tube clip Richard. I watched it and a couple of others that the nice U tube browser suggested for me. I think I now have a basic understanding of how a diff works. Isn't it satisfying to learn new things. Regarding my problem: I found that the near side drive shaft was not fully engaged Doh!!
Thanks all for you helpful suggestions.
Paul94
#7 agent_zed
agent_zed
  • Community user
  • 2,892 posts
Posted 08 August 2012 - 09:13 PM
glad it was a simple fix. diffs still boggle my mind. i understand the principles but if i try and follow it round in my head it just doesn't make sense :crazy:
#8 Simon B
Simon B
    Disco, aka "Doc" Brown
  • RHOCaR 18
  • 2,127 posts
  • Car type:Zero WB aka GT
Posted 09 August 2012 - 10:48 PM
Diffs I can understand. It's the automatic geaboxes and overdrives that are tricky :)
Even LSDs I find a bit hard ...
It amazes me how anyone thought these up in the first place :)
Simon.
Passed IVA 31-1-2012
Registered 5-3-2012 (At Last !)
Photos of build available at:
Web site: http://www.sj-bradley.talktalk.net/
Also tagged with one or more of these keywords: Differential
